DE prep
I have a 91 S2 with 59,000 miles on it would like to try some DE's next year. I have the original rubber clutch in the car. Would I be crazy running the original clutch or should I change it out this winter. So far it's working fine with street driving and some occasional hard launching.
Jim
91 944s2
Old 09-09-2009, 03:40 PM
fast924S's Avatar
Send a message via AIM to fast924S
You should be fine, Dont replace it unless its busted. I would check over all your bushings and DOUBLE check your ball joints. Make sure you have NO play in any suspension or bearing parts. Also I would change the oil, FLush the Brake system is a MUST, Make sure you have a good firm brake pedal and at least 50% pad life. May wanna change the Tranny fluid too. DE's arent to hard on the clutch its Auto cross thats tuff on it.
Your gonna have a Blast. I just started DE's this year ran 3 events and one was a double day. Its RETARDED FUN. You learn alot, and your gonna be amazed at what your car can do. These cars are No joke. They can Pull some serious G's in the corners. Get ready to chase Those 911.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-09-2009, 05:13 PM
Non Compos Mentis
Stock Porsche components are definately up to the task of track driving, as long as everything is in good condition.
When you start down that slippery slope, and "need" a set of R-compound tires for your next track day, then you may need to start looking at upgrades.
CAUTION: I attended a DE a few years ago, and now my car has a roll cage, and big numbers on the door.
Old 09-09-2009, 05:59 PM
Aslet's Avatar
I have done 7 DE days with my car, which has a rubber disk (rather worn out I just found out too). I wouldn't spend the money unless you need to change the clutch anyways, in which case you would get the spring disk no matter what... Like Dantilla said, its a very steep slope. Just get some experience and days under your belt before you decide to start spending money!
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 09-09-2009, 06:14 PM
Quoted for TRUTH!
Beware the R-Comp.
Old 09-09-2009, 06:24 PM
In the Fires of Hell.....
kdjones2000's Avatar
Ain't that the truth! I have my set of RA-1's now, and couldn't be happier come DE day
You will soon find out that that old worn suspension needs replacing as well, maybe with some upgrades along the way. Ah, the slippery slope....
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 09-09-2009, 09:08 PM
Toofah King Bad
Rasta Monsta's Avatar
Refresh the brake fluid with quality stuff. Consider refreshing coolant, or even pulling/flow testing radiator. Consider performance brake pads.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-09-2009, 10:46 PM
924RACR's Avatar
+1, watch where you go with this... my wife did her first DE a coupla years ago... despite only getting maybe 1 per year... well... she's now finishing up her first year as a rookie racer, and gets rather pissed when there's no-one for her to chase and pass... said it's as boring as DE... my, how quickly we get jaded!
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 09-10-2009, 04:50 AM
I went to Elkhart Lake last weekend and watched the club race and DE event. The DE event looks to be more my speed and budget. So far I've done the following: new belts, rollers, water pump, coolant hoses, oil cooler hoses, timing chain upper pad, yellow Konis, KLA upper strut mount, ball joints, stock front control arm bushing, 968 rear control arm bushing, 968 M030 F & R sway bars, KLA front sway bar brace, new rotors, Hawk HPS pads, ATE blue brake fluid, and SS flexible brake lines. I've been holding out doing the clutch until necessary as I'm not looking forward to all of the work.
Jim
91 944s2
Old 09-10-2009, 06:06 AM
are you thinking of DEing at RoadAmerica? that's a very fast course and very hard on the brakes. i would recommend you upgrade to at least Hawk HP+ pads for the track. keep the HPS's for your daily driving.
remember to brake early at 5. u don't wanna be finding out last second that you don't got brakes. heh. i hope to make it up there with PCA next year. I gotta get my 6pt harnesses installed. They won't let me run again with my Schrothe Rallye4's
Old 09-10-2009, 06:37 AM
924RACR's Avatar
Well, you could always go ITR (SCCA) with that puppy!
Vaughan Scott
http://www.924.org
Old 09-10-2009, 06:59 AM
i would say change the original rubber clutch this winter so that you have a happy summer of DE's next year. IT WILL FAIL. the S2 has way more power than the regular 2.5's so just change it now!
2000 Audi A6 4.2 - Current DD
1991 944 S2 - sold
1986 951 - departed
1988 924S - departed
1980 928S - sold
Old 09-10-2009, 08:47 AM
bearone2's Avatar
de's are very controlled and you will probably see 4 door sedans, m3's, ricers galore so you're not gonna get a lot of time to stretch out and let the hammer down.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 09-10-2009, 09:19 AM
watch out for those ricers. u never know when u'll have a 400hp eg hatch that weighs 1500lbs.
Old 09-10-2009, 09:56 AM
bearone2's Avatar
ain't that the truth
Old 09-10-2009, 10:40 AM
I got about 6 DE days out of my old rubber-center clutch (73,000 miles). Even when it went bye-bye, it was driveable with a gentle clutch-foot.
And I'd firm up the suspension before going with RA1s. I used RA1s with 20 year old suspension parts, and it was not pretty. Old rubber bushings from West Germany are not compatible with .99Gs.
1988 944 Guards Red (track/fun)
2002 C32 AMG (commute/fun)
Old 09-10-2009, 11:32 AM
