Send a message via AIM to ScoobySteve
10mm triplesquare in SoCal
Does anyone know where I can get a 10mm triplesquare (cheesehead) in SoCal...today?
Due to some miscommunication I thought my mechanic buddy had one and he thought I was talking about something different.
Old 09-14-2009, 06:58 AM
Custom User Title
mikepellegrini's Avatar
I've bought 'em at Autozone up here in WA - you have those down there, I think.
It seems like a lot of parts stores have them - as long as you ask for triple squares. If you ask for a cheesehead tool, they just give you a blank stare...
You want good ones, SnapOn makes a great set, but they're pricey.
83 944 NA - Black on black
86 951 - Red
97 Ford Expedition
He who hesitates is lost.
Old 09-14-2009, 07:09 AM
In the Fires of Hell.....
kdjones2000's Avatar
Pep Boys should carry a set of them....
Good luck, Keith
NASA/PCA Instructor
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
Old 09-14-2009, 09:26 AM
Redline Racer
HondaDustR's Avatar
Yeah. They carry a set made by OEM called 12 point internal metric set. It's a set of 4 that are large bits that fit into a 1/2" socket, or can be turned with a 1/2" wrench and it's like $20. They're not the best, but as long as you don't twist them out of the screw head, they work pretty well. Mine have taken multiple flywheels, cam bolts and CV joints off without a problem.
1987 silver 924S 210k mi! - Rebuilt motor survived 60K so far. Bottom end balanced, Custom mild ported head, Port matched intake, LR 944MAX chip, Thush Welded muffler, Bilstein shocks, MSD Blaster 2 coil, ect ect...Needs 8 more valves!
2003 Hyundai Tiburon GT 2.7 V6 24V DOHC- New toy/backup plan...Borla cat back, Injen intake. Needs headers and a real set of cams.
Old 09-14-2009, 10:31 AM
Bought mine at NAPA in TN.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 09-15-2009, 10:52 AM
