-   -   Window roll up (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/500580-window-roll-up.html)
xupkid2 09-21-2009 07:06 PM
Window roll up
Wondering if there is a way to manually roll up a window when the battery is disconnected. Im unable to connect a battery but need to roll the window up. I have access to the motor and it appears to only have 2 wires connected. One blue and one blue w/ a stripe. Any thoughts on how to get the window up? Is there a way to manually do it?
Any help is appreciated.
Brian
rb101 09-22-2009 03:58 PM
apply +12v to one of the leads and ground to the other. If window goes up, you are good, if not then reverse the leads.
