Need help with labor costs????
OK, so i found a 944 that has a few problems. Can you guys let me know how diffuclt each would be and approx. cost for labor. All parts come with the car. Thanks
1. hole in power steering return line
2. One of the brake wear sensors needs replacing,
3. Needs seal for the sunroof
1988 Satin Black Metalic , Plaid interior 944 "Celebration Edition" Sold and now autocrossed in canada
1985.5 Guards Red 944na 66,000 miles (SOLD in 2002 )
http://porsche944celebrationedition.weebly.com/
Old 09-28-2009, 09:48 PM
If you are slightly mechanical you can do all those easy. Sunroof seal depends on which side. One side is $12 one is $120
Old 09-28-2009, 10:54 PM
Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
You only 1.5hours away from me. sweet.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 09-29-2009, 12:46 AM
yep.. im right off i80
Old 09-29-2009, 09:27 AM
We'll have to go driving one day.
Old 09-29-2009, 10:28 AM
thekidd's Avatar
Send a message via AIM to thekidd
NE Philly (Bucks Co), may be right in the middle of you two. But, anyway, the break wear sensor shouldnt be all that hard. There is only 1 on the car- front drivers side. I forget exactly where it is, but if you know how to change a brake pads then it will be a since- brake pads are pretty easy to do. Just take the wheel off and take a look a raound. The sunroof seal should be fairly easy to replace by yourself. People probally have them in the parts section- the seals are all the same I beleive. The power steering return line. I have never worked with my PS before, but doesnt look all that complicated, local parts store may have some rubber tubing that you might be able to use. exitwound lives in State college, has a lift, and 2? of his friends have 944's.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 09-29-2009, 09:56 PM
thill944's Avatar
I wouldn't even bother with the brake pad sensor. Just tape the wires together.
Old 09-30-2009, 08:02 AM
