radiator fan plug
I am having no luck trying to find an electrical plug. It is the plug for the radiator fan switch. (951-606-481-00-85-M2) The switch is three prong. I have the switch but I need the plug that pushes into it. Is this part even sold separate?
www.Only944.com Porsche parts, Only better, Only944 87 944 N/A 165,000 miles 84 944 Saved by God, because I could not. |
the guitar guy
are you looking for the sensor to turn on and off the fans or are you missing the plug that goes to the fan it's self ? any who, the sensor is just under the upper rad. hose on drivers side of rad. other wise i would suggest going to a salvage yard near you and cut one off of another car and wiring on to your wire harness. i guess i'm just a tight wad.
I am talking about the sensor that turns on and off the radiator fan. The sensor on the driver side right under the radiator hose. I have the switch in the car but I don't have the plug that pushes into the sensor. I would rather just buy the plug if possible.
Toofah King Bad
There is no plug on my cars, it's a pair of insulated male spade connectors.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Same here...I'd be interested in one too.
Rick Harrison 1988 944S 17 inch Cup 2's, euro bumper conversion Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake MaxHP chipped |
On the S2 there is a flat 3-prong plug and rubber insulated too.
You can rig individual female spade connectors and just plug individually on the sensor.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. Last edited by bazar01; 09-30-2009 at 06:45 AM.. |
