Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
Sunroof loose when closed.
First im pissed because I took pics and my camera didnt save them to the mem stick so S@#$.
Anyways. When my sunroof is closed I can push up on it and it will move up a bit. maybe an 1/8" maybe a bit more. It's definitely not tight. Im wondering if this is normal or no? Im thinking no because that would be retarded.
I checked the lifting arm to see what it's position is and the arms pin is just below the top of the track. Is it suppose to be be at the very top? Is it possible that the track and somthing is worn that would cause this?
Also... it seems the the front of the sunroof lifts more than the back does. I have some cracked plastic up there such as the deflector hinged the the pieces that hold the front of the sunroof down. You think that could be causing it? I am going to replace the plastic pieces I am just wondering if it's the cause. Thanks.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 09-30-2009, 10:41 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Check also the sun roof air deflector hinges for breaks and wear. Especially at the joint in the hinge - if that is broken the top will be loose. The hinges are not all that expensive to replace.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-01-2009, 09:50 AM
I have cracks in them but I didnt think it would cause that much freeplay with the sunroof. I will replace them right away then. Thanks.
Old 10-01-2009, 02:18 PM
Garage Helper
Wel just grab each one and try to wiggle it up and down - if it wiggles in any way then replace them - About $20.00 each here at Pelican (Cheapest in town) - 477.871.635.A (left) and 477.871.636.A (Right)
Have pfunn
Old 10-01-2009, 03:13 PM
Have pfunn
Ahh I'll take your word for it. Im going to order what I need tonight. Tomorrow I am dedicating to my car. I still have a whole box of ignition stuff to install.
Old 10-01-2009, 06:29 PM
