HELP!!! Oil Pressure Dropped to 0
So I was out driving and at a light the oil pressure dropped to 0. I turned off the motor. Light turned green and I restarted. Oil pressure went to 2 bar then faded. I pulled off to the side of the road and am waiting for the tow truck driver. Per dipstick, car has oil.
Any ideas? |
Steve weird same thing just happened to me see my post!
1991 944 Turbo 2012 VW Passat 2008 Mini Cooper |
Yeah, I just saw that. Where is the best place for them to attach the hook for the flat bed?
On a stock 944, the "best" place (more only) if on the front control arms...
As far as the oil pressure, what oil are you running? I have never had an issue on the street, but on track I have overheated. It could be your running a light weight oil and it over heats...?
-Randy 1984 944 -Race car project 1993 968 coupe- Amazon Green |
-Stephen 00 Boxster S 6MT 03 Subaru WRX w/EJ207 swap 16 Cayman GT4 21 Genesis G70 3.3T |
Redline Racer
Both are possibilities. Also could be a cracked oil pickup tube. I know that's kind of a weak point in the car. Paper towels also come to mind...
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Back from Beyond
Always start by putting in a flywheel lock and retorquing the crank nose bolt. It's amazing how many issues that solves.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Scooby, I hope you are not going back to the same mechanic that misaligned your OPRV and caused it to break in half. Now, it's a loose crank bolt.
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Update...
Just got a call from the mechanic.
Crank bolt was fine. Car really had no oil pressure (not a gauge problem). The OPRV jammed in the open position. He inserted the alignment tool and determined that the housing IS properly aligned. He indicated that despite the high cost, he does not feel comfortable installing used OPRVs from unknown sources, even they have been taken apart and resealed. For once, I've decided not to cheap on this...as it's such a critical item. Well, there goes the budget for the Konis...
It is currently at the (much more expensive) shop of a Porsche Master Tech who was at Beverly Hills Porsche when 944s were still sold new.
