moorepower's Avatar
Anyone tried Pelican's "Super Mount" motor mount
Does anyone have opinions of these mounts? These aren't the solid type mounts. They have the rubber insert in them. I like the design, but I wonder if they transmit any more vibration than a stock mount.
Dan
Former owner of: '88 924LE (Luddite Edition) manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5 torsions, 931 valance and header panels, 6X16 Fuchs, lowered, etc, etc.
Old 10-12-2009, 07:39 PM
flash968's Avatar
they do - i had them on my car for about 10 minutes - yanked them right back out and put the stock mounts back in
Old 10-12-2009, 11:13 PM
moorepower's Avatar
But they're soooo pretty.....
Oh well, I guess it's OEM, then.
Dan
Old 10-16-2009, 01:28 PM
Send a message via AIM to flosho Send a message via Yahoo to flosho
What did you guys expect when putting solid or anything non-oem quality motor mounts in your car? That's the entire point to limit movement of the motor and stiffen it all up. Of course you're going to get more vibration. Vibration can be even more noticeable depending on the clutch/flywheel setup you have.
-efi via some megasquirt stuff
Old 10-16-2009, 01:31 PM
moorepower's Avatar
Well, they're not solid mounts, and they're not really marketed as a performance upgrade (ie, stiffer). They're supposed to offer "superior operational longevity when compared to stock mounts". But if they're doing that at the expense of vibration control, then that's not what I'm looking for.
Dan
Old 10-16-2009, 01:44 PM
Toofah King Bad
Rasta Monsta's Avatar
Flash, how many components have you installed and removed for this reason?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-16-2009, 01:46 PM
flash968's Avatar
lol - i've installed and removed a number of things for one reason or another - it has been an adventure for sure
these got removed because they transmitted too much vibration
the threaded rod is also too weak - it bent in just a few minutes of running - i know somebody else who broke one their first time out at the track - both were on 968s though, which are heavier engines with a lot more torque than a 944
Old 10-16-2009, 02:01 PM
banana944's Avatar
240$ for that early tranny set like that is robbery. Those are damn expensive too. Its a machined block of billit with a couple holes drilled in and a rubber bushing.
Old 10-16-2009, 07:10 PM
Try looking into a set of 968 type mounts
86 951 blk
Old 10-17-2009, 03:38 AM
