Toofah King Bad
Rasta Monsta's Avatar
Fuel Pump Jammed - Dirt? Poor current?
So, my 951 sourced pump has jammed up again. The first time was right after I replaced the tank, so I blamed it on a bit of dirt stopping the roller. When I pulled the pump and jumped it from the battery, after a few taps of juice, it started again and has been fine for months. Now it seems to be jammed again.
So here are my questions:
1. Cause of jam - bit of dirt, or failing pump?
2. Why does the direct battery jump revive the pump - inadequate amperage at the plug due to bad splice job? (951 fitting spliced onto "early" power harness)
TIA
rasta
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-14-2009, 01:14 PM
This has happened to me too. Something along the lines of hydrolock?
Old 10-14-2009, 01:38 PM
Toofah King Bad
Additional info. . .just tried to jump the pump again from the battery. No happy whirring like last time, now just a pathetic "clunk" when power is applied, in either direction.
Old 10-14-2009, 02:24 PM
schwank's Avatar
So you killed it! This was the one from my 86?
life is participation in evolution
87 944 racer . PRO44 #1
01 986S endurance racer
93 968 coupe 6spd
Old 10-15-2009, 03:12 PM
Toofah King Bad
Now that you mention it. . .
:P
Old 10-15-2009, 05:59 PM
jasonmx5's Avatar
This just happened to me as well! I just changed the fuel filter and now, clunk and nuthin. If I keep trying I can get the car to start, but it takes a few tries. What's up with that? How'd I kill the fuel pump when changing the filter?
"Making things easy is hard work"
My current stable: 1991 Carrera 4 Cabriolet, 1992 Mazda Miata, 2004 Lexus RX 330, 1994 F150 4x4 Supercab
Also rans: 1977 Carrera 3.0 (traded for C4 Cab.), 1983 944 (project car - sold)
Old 10-16-2009, 11:59 AM
Toofah King Bad
Did you get the filter flow direction correct? Clean your intake screen?
Old 10-16-2009, 12:19 PM
jasonmx5's Avatar
I think so and yup. If I'm under the car with my legs sticking out from under the rear bumper (head toward the front end - and not somewhere else unmentionable) and looking up at the filter, fuel flows from left to right, correct?
Old 10-16-2009, 01:48 PM
There should be an arrow on the filter and it points toward the engine.
Cheers,
Larry
Old 10-16-2009, 02:55 PM
jasonmx5's Avatar
The arrow does indeed point toward the direction of the engine as prescribed. Should I try swapping relays? I think I have a few floating around somewhere.
Old 10-16-2009, 07:10 PM
Sounds like the pump is seized by a bit of crap. Common on these Bosch pumps with steel rollers. Have you tried blowing compressed air through the pump? From both directions? And while applying power? Hopefully if it dislodges the air will blow it right out.
Also could try hooking 2 batteries in series to give 24V and giving the pump a hit. Shouldn't hurt for a brief period and will quadruple the power (torque) of the pump. Again with a good 100PSI of air behind it.
Old 10-17-2009, 03:50 PM
