-   -   I let run my diagnosis over with you guys (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/505585-i-let-run-my-diagnosis-over-you-guys.html)
AZ_porschekid 10-17-2009 09:10 PM
ok my noid light finally came today, came out that i was right about no juice getting to the injectors. well i also not getting any tach bounce, no juice at the speed and reference sensors plugs, she also isn't getting any spark. "pulled a plug and cranked her over" I also replaced the S&R sensors with new ones just to be sure. I'm pretty sure it's the computer now. is that a Norm for bad computers?
I just want to be sure before I'm able to borrow or buy one..
jpk 10-18-2009 04:58 AM
Can you confirm that the DME relay is good and sending power to the DME? Can you confirm that the ignition switch is good and signalling the DME relay to close?
Cover the basics first before you go jumping off the deep end. The Motronic DME is pretty robust; they don't often just "go bad".
Have a look at the garage shop manual section on clarks-garage.com and start with the DME relay testing section.
mattdavis11 10-18-2009 05:27 AM
Check your + battery terminal. The power lead for the DME corroded on me causing a similar problem. You might need to pull the sheath back a bit.
Grandad#3 10-18-2009 12:23 PM
Hi Levi, Check all the above. The ignition switch module forward of the key has a bad habit of cracking and losing contact inside. You will still be able to turn the engine over with the starter, but you will get NO SPARK from the coil. Also check the fuse in the top row, second from left. It is a fuse for the fuel pump 16 amp. It may look good, but replace it with a new one anyway. I hope this helps.
Cheers,
Larry
Rasta Monsta 10-18-2009 01:30 PM
Good advice, they are cheap. . .actually on my "just bought a new 2.5" mandatory refresh list.
AZ_porschekid 10-18-2009 02:05 PM
I actually have an early cat, so no DME relay. I think i might as well replace the fuel pump relay, and get some fuses. It's definately worth a try. As for the battery terminals when i first bought her i was able to pick up a used one at a parts dismantler.....
John I agree, they just don't go bad all of a sudden, but right now she hasn't ran for close 6 months.
For the ignition switch it doesn't look like their is anyway to test it without removing the steeering colum?
Complicated little car i have.
John_AZ 10-18-2009 03:01 PM
The DME relay and the fuel pump relay are one in the same.
993-615-227-00-M76 Fuel Pump/DME Relay, 924S/944/968 All (1983-95), Each
Brand: Stribel $25.25 Pelican
DIY repair:
http://www.dietersmotorsports.com/tech/2001/DME_relay_failure.htm
2-4-1
GL
John_AZ
Eldorado 10-18-2009 03:44 PM
Put a meter on the connections to your starter and turn the key to test the ignition switch.
AZ_porschekid 10-18-2009 05:17 PM
http://forums.pelicanparts.com/uploa...1255914170.jpg
http://forums.pelicanparts.com/uploa...1255914634.jpg
I just stopped by BAP and they sold me secound relay shown in the pics above. "the grey one" it appears it is supposed to plug into the where the "24 relay" is shown above. From what i understand is that the fuel pump relay should be directly under the fuel pump fuse. '#2' but that spot is empty on mine....
I'm soo confused.
anotherblack944 10-18-2009 05:56 PM
Originally Posted by AZ_porschekid (Post 4960076)
Now my relays really doesn't look like anything of the reference one from the manual. plus i have that circular looking relay thing. I have no idea why that's their, or what it's to.....
Just a WAG (never having looked at mine) but I'd guess the round one is either for the turn signals or the hazard lights?
AZ_porschekid 10-29-2009 05:22 PM
I came home from practice and My DME relay finally came! I poped her in and now, i have all the insturement panal lights came on, and now she turns over with tach bounce!!!!
I left it at that since it's pretty dark in my driveway, i'll dig in on saturday because tomorrow i have a game... =]
Grandad#3 10-29-2009 07:27 PM
Go to the link below for a Relay and Fuse Chart for your car. Oh ya, read each artical as well.
http://www.frwilk.com/
Cheers,
Larry
Dean924s 11-01-2009 05:45 AM
Cheers,
Larry
I put one together a while back for my 924s. Since yours is an early car it should be applicable as well.
Fuse & Relays 924s
PDF of the same
http://www.ehadesign.com/~dsmith/924s_Fuse_&_Relays_wwm.pdf
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
