Arizona_928's Avatar
I let run my diagnosis over with you guys
ok my noid light finally came today, came out that i was right about no juice getting to the injectors. well i also not getting any tach bounce, no juice at the speed and reference sensors plugs, she also isn't getting any spark. "pulled a plug and cranked her over" I also replaced the S&R sensors with new ones just to be sure. I'm pretty sure it's the computer now. is that a Norm for bad computers?
I just want to be sure before I'm able to borrow or buy one..
85 928S; LSx conversion, 5 speed with LSD.
IRR... What IRR!
Old 10-17-2009, 09:10 PM
jpk jpk is offline
Can you confirm that the DME relay is good and sending power to the DME? Can you confirm that the ignition switch is good and signalling the DME relay to close?
Cover the basics first before you go jumping off the deep end. The Motronic DME is pretty robust; they don't often just "go bad".
Have a look at the garage shop manual section on clarks-garage.com and start with the DME relay testing section.
-John
'94 968 Iris Blue
'85.5 944 White - Rally Cross and wrenching practice
'84 944 Gemini Grey (gone, but missed...)
Old 10-18-2009, 04:58 AM
Just thinking out loud
mattdavis11's Avatar
Check your + battery terminal. The power lead for the DME corroded on me causing a similar problem. You might need to pull the sheath back a bit.
91 FJ80
84 Ram Charger (now gone)
Old 10-18-2009, 05:27 AM
Hi Levi, Check all the above. The ignition switch module forward of the key has a bad habit of cracking and losing contact inside. You will still be able to turn the engine over with the starter, but you will get NO SPARK from the coil. Also check the fuse in the top row, second from left. It is a fuse for the fuel pump 16 amp. It may look good, but replace it with a new one anyway. I hope this helps.
Cheers,
Larry
Old 10-18-2009, 12:23 PM
Toofah King Bad
Rasta Monsta's Avatar
Good advice, they are cheap. . .actually on my "just bought a new 2.5" mandatory refresh list.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-18-2009, 01:30 PM
I actually have an early cat, so no DME relay. I think i might as well replace the fuel pump relay, and get some fuses. It's definately worth a try. As for the battery terminals when i first bought her i was able to pick up a used one at a parts dismantler.....
John I agree, they just don't go bad all of a sudden, but right now she hasn't ran for close 6 months.
For the ignition switch it doesn't look like their is anyway to test it without removing the steeering colum?
Complicated little car i have.
IRR... What IRR!
Old 10-18-2009, 02:05 PM
Proprietoristicly Refined
John_AZ's Avatar
The DME relay and the fuel pump relay are one in the same.
993-615-227-00-M76 Fuel Pump/DME Relay, 924S/944/968 All (1983-95), Each
Brand: Stribel $25.25 Pelican
DIY repair:
http://www.dietersmotorsports.com/tech/2001/DME_relay_failure.htm
2-4-1
GL
John_AZ
Old 10-18-2009, 03:01 PM
Eldorado's Avatar
Put a meter on the connections to your starter and turn the key to test the ignition switch.
Old 10-18-2009, 03:44 PM
I just stopped by BAP and they sold me secound relay shown in the pics above. "the grey one" it appears it is supposed to plug into the where the "24 relay" is shown above. From what i understand is that the fuel pump relay should be directly under the fuel pump fuse. '#2' but that spot is empty on mine....
I'm soo confused.
IRR... What IRR!
Old 10-18-2009, 05:17 PM
Now my relays really doesn't look like anything of the reference one from the manual. plus i have that circular looking relay thing. I have no idea why that's their, or what it's to.....
Just a WAG (never having looked at mine) but I'd guess the round one is either for the turn signals or the hazard lights?
Old 10-18-2009, 05:56 PM
I came home from practice and My DME relay finally came! I poped her in and now, i have all the insturement panal lights came on, and now she turns over with tach bounce!!!!
I left it at that since it's pretty dark in my driveway, i'll dig in on saturday because tomorrow i have a game... =]
IRR... What IRR!
Old 10-29-2009, 05:22 PM
Go to the link below for a Relay and Fuse Chart for your car. Oh ya, read each artical as well.
http://www.frwilk.com/
Cheers,
Larry
Old 10-29-2009, 07:27 PM
One apex at a time
Dean924s's Avatar
Cheers,
Larry
I put one together a while back for my 924s. Since yours is an early car it should be applicable as well.
Fuse & Relays 924s
PDF of the same
http://www.ehadesign.com/~dsmith/924s_Fuse_&_Relays_wwm.pdf
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 11-01-2009, 05:45 AM
