Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
Will program for food
ghnat's Avatar
Door lock issue
When I lock or unlock the door using the key, the other door is supposed to lock/unlock but it doesn't. This is the same for both driver and passenger doors.
Anyone know some tests I can perform to find what is wrong? I do plan to take the door panels off and see what is what.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 10-28-2009, 02:09 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Banging a Uey
Tishabet's Avatar
what happens when you use the central locking button in your central console?
Grant
2008 Mini Cooper S
1989 Porsche 944
1961 Solex 2200
1938 Buick Special
Old 10-28-2009, 05:57 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
ghnat's Avatar
I can hear the actuators move. The LEDs light on and off, but the black stocks do not move up and down. Maybe too much friction?
Greg Hnat
98 Jeep Cherokee
Old 10-28-2009, 06:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Right Wing Extremist
stogie25's Avatar
At least on my '88 either door lock opens both doors. Does your driver's door lock not open the passenger door? Does the passenger door lock open the drivers? What does the button on your console do (mine only works with both doors closed)?
black 1988 Porsche 944 (mostly stock)
black 1997 Jeep Wrangler (very modified)
I didn't know cars came in other colors
Semper Fi
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Buy a cheap door panel removal tool from your local auto parts store. Clean and relube all moving parts for the door locks. See if they operate good prior to replacing the door panels. May be a sticky switch, spray with electric parts cleaner and work switch several times.
Cheers,
Larry
Old 10-28-2009, 06:55 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
In the Fires of Hell.....
kdjones2000's Avatar
Most likely problem is that one of the doors has the plastic arm that actually opens/locks the lock has broken. It is very common.
As mentioned above, get a tool to remove the panels and you should quickly find the problem.
The arms are like $2 or less from the dealer.
Good luck, Keith
'88 951 - with M030, M758 turbo/brakes, M490, M685, M335, LBE, Guru chips, 3Bar FPR, LR high vol fuel pump, 1.3mm shimmed WG
Old 10-28-2009, 09:05 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
ghnat's Avatar
thanks for the tips. I'll try go look at them over the weekend. I have taken to door panels off before, but for other reasons.
Greg Hnat
98 Jeep Cherokee
Old 10-29-2009, 04:19 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Custom User Title
mikepellegrini's Avatar
The factory manual has a really good section on diagnosing problems with the central locking system.
83 944 NA - Black on black - http://clarks-garage.com/phpBB2/viewtopic.php?t=5931
86 951 - Red - http://clarks-garage.com/phpBB2/viewtopic.php?t=7437
97 Ford Expedition
He who hesitates is lost.
Old 10-29-2009, 04:30 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
ghnat's Avatar
Well, I feel silly for posting. I took the doors apart and the actuators were not attached to the black stocks. I attached them and whammy, working....
Greg Hnat
98 Jeep Cherokee
Old 11-06-2009, 11:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Consider yourself lucky,,, you got yourself an easy one there. Most things on these rides aren't that easy.
86 951 blk
Old 11-07-2009, 02:05 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
