Avatar's are to SMALL.
Send a message via Skype™ to cvriv.charles
I pulled my plugs again,...
First,... I took into consideration the NGK BPR7ES plugs this time around,... EXCEPT i used the Autolite version because I could get thats locally for just as cheap. Anyways,... the plugs actually look alot nice this time around. Not all burnt up like the stock bosch plugs.
But,... I did find some oil on the threads for Cyl# 1, 2, and 4. Cyl# 3 was dry and beaultiful. So there was some oil on the threads of the other plugs. Not a HUGE amount but enough to make me worry a bit. I rubbed my thumb across the threads and I got a nice line of oil from what was collected by the crush ring. There was a tiny bit of burnt up oil on ring portion of the tips.
My question is,... is this ok? Or or this an early warning sign of something? What are the possiblilities? I know that one possibilty could be piston rings. I am hoping this is not the reason but I wont deny it. Anything else? Am I looking at a very soon complete engine overhaul?
Maybe I should do a leakdown. Any tutorials for doing a leakdown? Never done it before.
1986 951 - Wrecked. Being used for engine swap and parts.
1987 944 - SCCA specification track/ street car. Awaiting 951 engine and parts.
Old 11-01-2009, 10:13 AM
Proprietoristicly Refined
John_AZ's Avatar
Tutorials.
You might begin with the compression test.
Remove the DME/fuel pump relay or you will wash your cyl with gas
Harbor Freight usually has a decent leak down tester for $40 or on sale.
Compression-leakdown test
and
How to Perform a cylinder leak test efficiently Bentley Publishers
GL
John_AZ
Old 11-01-2009, 11:21 AM
Custom User Title
mikepellegrini's Avatar
You're sure it wasn't leakage from the cam tower gasket? My kid's 951, the No. 1 plug always had bunches of oil on it and it drove us nuts till we finally figured out it was coming from the cam tower gasket.
If the electrode portion looks relatively clean and the oil is only on the threads, I'd suspect the gasket, not the rings or valve stems seals.
83 944 NA - Black on black
86 951 - Red
97 Ford Expedition
He who hesitates is lost.
Old 11-01-2009, 11:24 AM
The electrodes are clean. Its just the threads that are coated. I will have to take that into consideration. I already have a leakdown kit. I just need to do it. The PO did a compression test and all the numbers were perfectly fine. So we'll have to see. I have plans to rip out the manifold to do some work under there. I might just go ahead and remove the cam tower I guess. Check things out.
Old 11-01-2009, 12:15 PM
Schumi's Avatar
On other cars, oil on the plug threads isn't always a bad thing, it usually comes from leaky valve cover gasket seals around plug holes that go through a DOHC valve cover. But the 8v 944's aren't like that. There is no reason for oil to be pooling around the plugs and obviously not in the cylinders. So it's definitely a problem to look into finding the source and fixing.
M
Old 11-01-2009, 12:52 PM
I will do a leakdown in the next few days. If thats checks out ok I will look futher when I remove the manifold.
Old 11-01-2009, 03:00 PM
