Porsche Crest Front Spoiler Repair
The front spoiler on my 1984 944 NA has a couple small rips, can it be repaired/glued? Also it has some warping/distortion at the center section. Is there any way to straighten it out?
Old 11-07-2009, 10:25 PM
There is a rubber bumper repair kit you can buy at your local auto parts store...
Old 11-08-2009, 12:34 AM
Custom User Title
mikepellegrini's Avatar
When I got my 83, the valence was pretty well toasted. The PO had driven the car over some curbs or something. There were a couple good rips and a bunch of gouges and scratches.
I took it off and using fiberglass and body putty, got it back in top shape. It was pretty easy.
The warping, I think, is mainly the support brackets on the car. You just have to adjust them (bend them) until the valence isn't deformed.
Here's pictures of mine:
There were good rips or tears in both sides, plus lots of other damage.
I reinforced the back of the tears/rips with fiberglass, so the rip would not spread.
Then using body putty, I filed in the cracks and scrathes and what not.
A whole lot of sanding went on.
Finally, after a whole lot of filling with body putty and sanding, I primered it and painted it with bumper paint.
The finished product looks pretty good.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 11-08-2009, 08:08 AM
Toofah King Bad
Rasta Monsta's Avatar
Somewhere out there too is a polyurethane repair kit, that recommends cutting out a "V" over your crack, and rebuilding it with this goop. Can't seem to find it now, someone will post it though.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-08-2009, 12:59 PM
Is there a way of straightening out warped/distorted areas?
Old 11-08-2009, 04:24 PM
Looks good Mike but the fiberglass will crack... Needs to be polyurethane or rubber.
Old 11-08-2009, 04:33 PM
VII VII is offline
When I got my car the rear bumper endcaps were terribly distored from what I would imagine was a rear impact and the PO must have let the bumper stay compressed for a while. I took them off and reshaped them with a heat gun. You may have similar luck.
Old 11-08-2009, 04:43 PM
Ya you might have some luck with a little heat popping it all out...
Old 11-08-2009, 04:49 PM
Custom User Title
I did that repair three years ago and yeah, just recently the cracks have reappeared somewhat - I s'pose the fiberglass is too rigid.
But it still looks good. You have to look close and know where to look to see anything.
Using the fiberglass on the back like I did worked okay - I figure three years ain't bad.
I'll take it off maybe next summer and repaint it - it needs the paint, anyway.
As to straightening the warped/distorted areas: like I said before, at least on the cars I've owned, it was the mounts (the metal braces/attach points) being screwed up that made the valence warped.
Try bending them to stretch the valence, and that may just get rid of the distortions.
16 Ford Expedition
Old 11-08-2009, 05:26 PM
Many thanks to all of you. When I will put the car in for the winter (yes I am still driving it in fairly good weather here in Buffalo, NY !!!)I will remove it and try the heat gun and the brackets. I will let you know how I will make out.
Thanks again, George.
Old 11-08-2009, 07:48 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
We have a strong polyurethane tape with hot melt glue on one side designed to bond to polyurethane coated fabric. We use it to weld (with a heat gun)some fabric covers together( these are not car covers) and it creates a very strong flexible waterproof joint.
This may be the answer to reinforcing cracked areas, but it requires maybe 5-600 degrees C on fabric, who knows what on bumpers.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 11-09-2009, 08:45 AM
