MStaz944's Avatar
need help with 944 headlight motor issue
I have a problem with my headlights going up and down on my 86 N/A 944. Headlights wouldn't go up even after I changed the relay on them. They worked when I put it away for winter. When I would manually put the lights up and then turn the headlights off to put them in the down position they went down!!! but they wouldn't go up when I turned them on. I switched out the motor and again the same problem. They will go down when in the up position but will NOT go UP when I turn them on.
ANY suggestions or ideas what might be the problem?? Has anyone had this same issue before??
Thanks everyone!
-Mike
Old 04-17-2014, 12:42 PM
Good luck with that!
I have the opposite problem as you. I put in a new fuse last nite and the lights would go up when I switch it on, but they wont go down when I switch it off. I left them up last nite and when I popped the hood to manually turn them down today, I noticed the headlight motor was warm/hot.
Is it possible the relay isn't dis-engaging after I turn off the switch/car? I had to jump it to start.
Silver '83 944 - RIP 12/12/2014
Old 04-17-2014, 12:57 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Porsche Crest Lubricate Concealed Headlight Linkage
Mstaz944;
Be sure to lubricate the Linkage-moving joints/parts in the pop up light assembly otherwise you may burn out motors prematurely. Every 6 months with with lithium grease (Spray with thin tube attachment) works best.
See Service Manual (s) hope this helps. Later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 04-18-2014, 06:26 PM
Send a message via Skype™ to massive
Did you manage to sort your problem?
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 08-03-2014, 09:00 AM
