YUP, correct type of anti-freeze has anti-corosion? additives. Use distilled water 50/50 mix with anti-freeze.
Use anti-seize on the entire shaft of the stud and threads.. then propper torque and warm/cold cycle, and check the torque again, if it's practical.. better way on this, since it will be covered up is to re-torque while things are still apart, when it's dead cold, like first thing in the morning. |
| All times are GMT -8. The time now is 06:38 PM. |
