did I fry my DME ???
I have been tracking a lean issue and decided to check my co level. I made a bypass for the o2 sensor to keep it warm started the car buy the time i got my volt meter and back to the car the bypass wire vibrated loose and the two wires contacted on the wiring harness side and the car quit and cannot be started. DO you think I fried the DME
1988 944 with early motor
1974 Bronco,
1965 BSA Lightning
Old 11-23-2009, 03:58 PM
one of gods prototypes
bell's Avatar
i'd pull the dme apart and look for some burned traces.....if something dead shorted it should be obvious either by the burnt component or trace.....
Brought to you by Carl's Jr.
Old 11-23-2009, 04:31 PM
thekidd's Avatar
Send a message via AIM to thekidd
I have an early DME and AFM if yours did fry up.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 11-23-2009, 04:51 PM
it was just the fuel pump fuse
1974 Bronco,
1965 BSA Lightning
Old 11-23-2009, 07:22 PM
