Racing Harness
Hey again, had a question of opinion, so in my '87 924S i wanted to put in racing harnesses, and was wondering if its possible to keep the stock seats in it, or if i would have to get racing seats and put those in?
Old 11-27-2009, 07:44 PM
Aslet's Avatar
Possible, yes. Safe, no. Without proper seats with holes for the harnesses, they can slip off of you in a crash.
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 11-27-2009, 08:39 PM
I can see how that would be a problem haha, now is it easy to put in racing seats and a harness in a 924?
Old 11-27-2009, 08:49 PM
not too hard...but most 4point harnesses aren't safe. and in order to run a 5 or 6 point, u'll also need a rollbar.
depends on what yer intending on doing. if yer just doing autocrosses, the schrothe rallye4's can be safe with proper seats. i just happen to be selling a set of them with a harness bar... :P shameless plug.
Old 11-27-2009, 09:09 PM
Do i need a harness bar if i want a 4 point harness?
Old 11-28-2009, 09:00 AM
http://www.**********.com/product.asp?pf_id=P911964&dept_id=4890#
would this work in a 924? how would i mount it if possible?
Old 11-28-2009, 09:05 AM
supposed to be ********** where the stars are
Old 11-28-2009, 09:06 AM
can you not post names of other Porsche sites on here?!
Old 11-28-2009, 09:07 AM
flash968's Avatar
there is a lot to consider when mounting harnesses
seats without slots for harnesses are not safe to be used with harnesses
harness bars must be the type that cannot allow rotation - many harness bars do not do this, which is why many of them are not approved for track use
harness bars must retain strap separation to be safe, and is a new requirement in some DE events
harness bars must be a minimum of 1.5" diameter with .120" wall or 1.75" diameter with .090" wall to be safe, and is a requirement in many DE events
4 point harnesses are not particularly safe, and should incorporate an anti-submarine belt, but if installed correctly are better than the 3 point stock belts
many states have prohibitive laws regarding non-factory belts - check your local laws
there is also a diagram that shows the angles of the belt straps - this is critical to the functionality and safety of harneses - there are minimum and maximum angles and lengths for each strap
Old 11-28-2009, 09:14 AM
certain sites are off limits heh. call em competitors sites :P
Old 11-28-2009, 10:17 AM
basically your options for high speed DE's are either oem 3points with stock seats, 5 or 6 points harnesses with a rollbar.
for autocross only, u can do 4 point w/ antisub and a harness bar. this setup is most likely not allowed in your PCA DE's. I only ran it once at PCA DE, although other organizations allowed me to run it just fine.
Old 11-28-2009, 10:23 AM
