Porsche 944 Lights problem
Looking for some help on a 1983 944 2.5 - the high beam on the left headlight won't work - it's not the bulb, the fuse or the switch. There is a yellow cable hanging near the fuse box but I couldn't find the wiring diagram for the cables assembly so I am not sure what it's for. Thanks
Old 02-05-2011, 09:03 AM
yarfk
kfray's Avatar
L1 in the diagram is the left headlight.
http://www.pelicanparts.com/944/electrical/924_78_2_1.jpg
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 02-05-2011, 09:23 AM
Thanks for the quick responce. If anyone has a picture of the rear side of the fuse box though...
Old 02-06-2011, 12:05 AM
I had a similar problem. Turns out it was a break in the wire at the loop where the wire bends before the headlight unit itself. I removed the wire protective sheathing and it was broken at the bend.
Old 02-06-2011, 05:37 AM
Thanks guys - there was no power at the fuse box so I had to go the mechanic after all - now there is an extra wire going in there but I have high beam at the end. Thanks again for the help.
Old 02-08-2011, 09:48 AM
