Toofah King Bad
Rasta Monsta's Avatar
Odd Sounds
I have been worried lately about what my 2.5 does when I fire it up. First, the tach needle moves up and hovers just under the one. When I press the gas pedal, it shoots up into the higher numbers, and there is a weird sound coming from up front. I can hear a slight whine that speeds up and slows down when I step on the gas, and it also sounds like s weird growl, almost like an exhaust sound.
To make matters worse, while running, the temperature gauge slowly rises until more noise comes from under the hood, like a loud "whooshing." Also, the longer I let it run, the less fuel it seems to have in it.
How concerned should I be?
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-07-2009, 02:38 PM
Custom User Title
mikepellegrini's Avatar
If you re-route the exhaust into the cabin, the problem will go away.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 12-07-2009, 03:22 PM
Proprietoristicly Refined
John_AZ's Avatar
I have been adjusting my hydrogen2O oxygen ratio to be more hydro-generous.
It eliminates the "whoosing" sound and my fuel mileage is increased to 35mpg.
It helped when I inflated my tires with nitrogen to roll smoother as well.
Old 12-07-2009, 04:23 PM
flash968's Avatar
check the chrome kidaedor valve - if it gets stuck it can do that, and rust your muffler bearings too
Old 12-07-2009, 05:11 PM
pontifex4's Avatar
How's your blinker fluid? When mine gets low, the pump cavitates and I hear a mix of the sound you're describing and Glenn Beck's voice.
Charlie
'99 996 C2 6 speed - Arctic Silver
Old 12-07-2009, 05:37 PM
Custom User Title
It could also be the Kuhneutson valve - a common but relatively cheap fix at $65 for a new part.
Kuhneutson Valve - $65.99 : KaleCoAuto, Hard to find automotive items!
They also have muffler bearings in stock, if that turns out to be the problem...
Muffler Bearing - $49.99 : KaleCoAuto, Hard to find automotive items!
16 Ford Expedition
Old 12-07-2009, 09:48 PM
John_AZ's Avatar
Thanks for the link.^
Many times I have wondered if there was a place to improve my intelligence. Now when I'm called an A**, I can tell them to shove it with "Brass Balls".
Old 12-08-2009, 04:09 AM
