-   -   Dashlights out. Fuse 9 blowing. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/514426-dashlights-out-fuse-9-blowing.html)
Ron-one 12-03-2009 07:24 AM
Hi, first mail so bear with me if I mess it up!
My son runs a '88 924S & I get to fix it as & when required! At present we have a couple of electrical problems you may be willing to help with.
He called last night to say that the dashlights are out. I've picked up on the ground connection in the footwell but before I go there could someone direct me to the fuse for these lights?
Secondly Fuse 9 (Fan, Sunroof & hatch release) in the auxiliary box blows regularly (roughly every 4 to 6 months), not obviously as in the element blows, more like it disintegrates at one end or the other. Anybody had this problem or any ideas why?
Many thanks
mikepellegrini 12-03-2009 06:56 PM
Welcome to the board!
The instrument lights should be on fuse 12. 13.0 Electrical
Have you seen Clark's Garage? Clark's Garage Service manual has a lot of valuable and useful stuff. Clark's Garage Home Page
As to the other fuse, you say it doesn't blow, but rather "disintegrates?"
The times I've seen that on my 83 NA (with the cooling fan fuse - #3), it was because the fuse circuit was overheating under heavy use.
In my car, the rear window defogger fuse (#4) had badly over heated at some time and partially melted the fuse box. My guess is that affected the other fuses, because they all got hot under heavy use (the closer to #4, the hotter). I was measuring temps as high as 185F - and sometimes (when the heater blower and the radiator cooling fans were all going) you could smell buring insulation.
The #3 fuse would get so hot the plastic fuse would melt (kinda like yours) - but it wouldn't blow. In the pic below, you can see how charred #4 holder is. You can also see how the plastic of #5 is looking kinda melted/charred.
http://www.mikepellegrini.com/Graphics/fuses.jpg
I fixed it by re-wiring the aux fuse box - I cut the wires from the box and put new modern fuses in-line (same amperage as before). Problem solved. No more over heating wires.
If you could find the same sort of fuse holders/connectors, then you could rebuild the aux box. The connector/holder is one piece. I looked but was unable to find anyone selling them.
The problem I think was caused by the crimp connectors on the aux fuse box fuse holders. I believe that when they got hot (by #4 over heating) that damaged the adjoining connecors.
Ron-one 12-04-2009 06:34 AM
Thanks for the response.
Dashlights are now back on (Fuse 12 replaced).
Will look at auxiliary fuse box over the weekend, sounds like Fuse9 overheating & with temperatures like 185F is there any wonder!
Thanks again
