Is this the standard 944 N/A chip?
While I have the DME out to look for ICV transistor failures (which I think I may have found), I took a picture of the chip installed for you to tell me if it's the standard chip. The previous owner was trying to 'track' the car I think and has done some weird things and I wouldn't have put it past him to have installed some funky chip in it hoping to get an extra 200 horsepower or something.
ANYWAY, is this the original chip?
chipin
Hey Exit:
I am thinking of chipping my two cars. I have an 86 and an 88. what sort of wierd stuff is it doing? landrover
1978 911sc cpe 1986 944 N/A sold to pelican 1965 series 2a 88 landrover sold 1964 series 2a 88 landrover sold 1988 944 white. sold |
I have a feeling that is not stock.
I think the stock chip does not have a window (the glass that exposes the eeprom chip) which leads me to another downer- you shouldn't have pulled the sticker off. Programmable EEPROM chips are erased by exposing them to UV light. Put it back on pronto. you probably haven't damaged it yet as it takes high amounts of UV to erase them, but it's not good. Especially do not expose it to sunlight.
M |
Yeah i only pulled it off for like the time it took to expose the print on the chip, indoors, in my dark room.
Anyone else? I have no idea what the stock and/or aftermarket chips look like. |
Give this site a try Power PROM default - from "The 944 Motronic DME" by FR Wilk Go to the " can I chip my Porsche 944" section, there are good pictures of the DME.
87 944 72 914 Sold 84 944 Sold 85.5 944 Sold 78 924 (first car) RIP |
Yeah I was there like 4 minutes ago. Unfortunately, the pictures aren't very clear and almost all are from early 944's.
Wow, FrWilk deffinately upgraded his site. Anybody on here still remember the hostile take over of his site and all the drama about him vanashing from this board?
Jaime O. Thank god I crashed or i would never have owned a porsche 83 944 daily driver (clutch and tt time) 85 325e BMW T-boned R.I.P. |
It doesn't look like it. Especially with the hand written sticker on it.
This pic is a little blurry, but you can see my stock chip in the board, and my aftermarket chip pictured up top (also has a sticker on it).
'88 Porsche 928 S4 - LSD - Sold '88 Porsche 944 N/A - Sold |
unindicted co-conspirator
i still have the stock chip from my '86 if you need one.
I replaced it with a FR Wilk
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
chip
looney
Can you tell the difference? I have an 88 and an 86. was thinking of chipping the 88. thanks have a good holiday landrover
I was hoping there was an easy way to spot the originals. BAH.
I'm not seeing any issue, I don't think... However, I've never driven a 944 with a known stock chip in it! |
i can post a pic of it tomorrow (i'm at work all day)
chip
Looney
I was asking is there a performance difference? landrover88
for what it's worth, 2 weeks ago i swapped out my performance chip and put the stock back in. (i'm doing a little experiment to see if i get better gas mileage). but to my surprise, i found no noticeable difference after i put the stock chip back in. none.
I noticed a difference with the Wilk chip.
The flat spot from 2500 rpm to 3500 rpm is gone. the power curve is nice & smooth It also fixes the return to idle shudder
See, I have a return to idles shudder, I believe. I can't be sure since I've never driven another 944, but it does fall to well below 1000rpm before returning to stable when clutching in.
