Brakes clicking
My brakes are clicking on my front passenger side wheel.
When i took the wheel off and spin in, theres a point where it makes the pad move. Making it click. theres a retaining spring clip thing in there that holds the pad on, could it be worn out? or could my rotor be bent? what should i check first? THanks, -Ryan
1985.1 Porsche 944-Koni Adjustable Rear Shocks |
....that's...wierd.
what do u mean when u spin the wheel? is it only at a certain spot that the pad can move laterally? or is it that there's always slack and the rotor catches it at a certain point? hard to tell...but those pins..i wouldn't expect to be a wear item. |
wrong pads? aftermarket cheap pads? or misboxed
When i spin the rotor, theres a certain point where it grabs, causing the pad to move.
About the pads, i'm not sure. Who knows what these PO's have done :P
hm.....yea i'll entertain the idea that the rotors are actually warped.
but typically pads don't move cause there's no slack between the pad and the rotor surface. once the piston presses down for the first time, there's never a gap. unless your wheel bearing is shot and the hub+rotor is wobbling. then yea..... |
I could see both the bearing and the warped rotors as a plausible cause if you have a straight edge you could do a very basic check for warped rotors but the edge of the rotor will be higher than the surface so it might be difficult. A bad bearing would probably make noise and there would be end play. this sure is an odd problem
if the pad itself is moving parallel to the rotor when you turn the rotor, something is wrong with the pad, either it got damaged, misboxed, or cast wrong, there should be almost ZERO clearance from the edges of the pads to the caliper, if this is where the pads have slack , get some new oem pads.
Back from Beyond
As above, but first adjust the wheel bearings so you can rule them out of the equation. Then you can look for a warped rotor or bad pads.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Video
hmmm the brake pad in shifting
Looks as if im missing the clip that goes between the pads.
good side clicking sideDoes anyone have one for sale?
ahhhh the spring clip.
can prob get it cheap from apartabove or maybe nick at bennington has extras he can toss into a small box |
ha yes sir. I never knew that part existed untill I took off the other wheel. lol
