cwiert's Avatar
checking clutch disk wear
hi.
i followed the instructions on clarks, and my measurement came to about .6 inches, or 15.24mm. I guess that's good right? It seems too good as clarks says that a new clutch is around 18mm and it should be replaced at 34mm.
I'm wondering if I did it right. It doesn't matter if the car is in gear, right? I just put the car in reverse, put the e-brake on, jacked it up and looked through the inspection hole and measured. is that all there is to it?
'88 Porsche 928 S4 - LSD - Sold
'88 Porsche 944 N/A - Sold
Old 12-30-2009, 08:01 PM
Proprietoristicly Refined
John_AZ's Avatar
To be more accurate, get a couple of deep sockets and instead of using a ruler or tape measure, stick a deep socket between the opening. Make it a socket that you can just barely get between the clutch fork and bell housing. Take it out and now measure.
Thats all there is to it. I put a new clutch disc in and my opening is about 15mm. I used a thicker aftermarket disc. OEM Sachs is a little thinner and like Clarks wrote, is about 18mm new.
Old 12-30-2009, 08:32 PM
There is also adjustment of the Clutch pedal springs itself. I've heard that can make a difference on a sort of preload to clutch. (ie early engagement) but I haven't found a good explaination of it.
Maybe check you clutch pedal is not much higher than you others...
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 01-01-2010, 12:07 AM
