Bosch Part No. for Fuel Injector
What is the Bosch Part Number for a 1987 944 NA Fuel Injector?
Thanks |
Proprietoristicly Refined
Hi guys,
I discovered something very strange today on my parts car(86 N/A),it has 951 injectors part number 0-280-150-803 and it works fine with no problems.I thought 951 injectors had different impedance and don't work on N/A's .How is this possible?
Catalin '86 DD Last edited by Catamax944; 12-26-2009 at 03:32 PM.. |
BAD---BAD
Same impedance=LOW BUT..... The turbo injectors may "work" but you are shoving a lot of fuel into the cyl. This is very bad on the cyl walls. In addition, fuel mileage is crap. Fuel flow turbo injectors=37.1 lb/hour Fuel flow NA injectors= 22.83 lb/hour You need to get the correct set. GL John_AZ |
ok,thanks John!
Catalin '86 DD |
Are these any good Porsche & Volkswagen Fuel Injectors - VW Bosch & Lucas Injectors .How would 24 lb/hour affect the engine? Where can i get a set of remanufactured or new injectors for good money?
Catalin '86 DD Last edited by Catamax944; 12-26-2009 at 05:11 PM.. |
Very close.
24.35 lb/hour. Actually for the Ford 2/3l Will work--YMMV 944_science bought a set. Page 2???? Cleaning Injectors Advice GL John_AZ |
Hugging the curves
Any specific year that we need to look for? Thanks |
Sorry, The chart I have does not show the year.
Bosch 0-280-150-159 were used on the Ford 2.3l and are a close substitute for the OEM Porsche 2.5l injector 0-280-150-158 Do not use the Bosch 0-280-150-160 that were also listed for the Ford 2.3l. These only have a fuel flow of 17.6 lb/hr |
