Certified Porsche addict
The Glademister's Avatar
Wiper system ground?
Early 944 or 924S.
Struggling with a inoperative wiper system. Rebuilt motor. Checked switch. PO cut a bunch of wires to remove radio. Does the wiper system ground terminate in the radio area? I noted that the wiper system shares the same fuse as the radio.
Here's the cut wires in the radio area...
1st harness... (I think this radio power and speakers)
Yellow
White
Red
Black
Brown
Br/Yellow
Br/Wh
Br/Grn
2nd harness
Brown (large, this is the one I suspect is the ground)
Rd/Bl
Rd/Wh
Brown (small with terminal)
Br/Wh (small with terminal)
(this harness also has the ash tray light and seat belt circuits - all intact)
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 12-23-2009, 05:25 PM
Just hook both Brown (ground wires) wires together and run them to a tempary ground spot to check your wipers out.
Cheers,
Larry
Old 12-23-2009, 07:31 PM
Checked the electrical diagram and it shows the wiper switch, wiper motor and the radio all grounded behind the firewall. That's got to be behind the fuse and relay panels. Bet there's something loose back there.
Old 12-23-2009, 08:19 PM
That is a spiders nest back there. You better take some muscle relaxer pills to work in that area. Don't forget to take the ground cable off the battery before you mess around back there.
Cheers,
Larry
Old 12-23-2009, 11:01 PM
Copy spiders nest. When I pulled the console I found a mouse nest down in the shifter well! Damn rodents had chewed through the inner and outer boots. A little rubber and a little leather - I guess they're not picky about their diet. LOL
Old 12-24-2009, 04:47 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Spiders nest
If you are working near the fusebox or under the dash (sounds like) consider removing the driver seat to get under there. It is only 4 bolts.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 12-26-2009, 09:32 AM
I've done that in the past and it does help to have the seats out for under dash fixes. I've got this wiper problem figured out. See my posts in...
Another '88 924S.
I appreciate the bits of info and help guys.
Old 12-26-2009, 12:01 PM
