-   -   Installing Adjustable FPR (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/518243-installing-adjustable-fpr.html)
piperporsche180 12-25-2009 07:53 PM
Hello, I'm installing an adjustable FPR, I plan on setting it at 3.0 BAR. It has a gage on it. How should I set it?
Should I find out what pressure the stock fuel pump produces and set my air compressor at that pressure then tune it based on that?
Any ideas?
Icey1174 12-26-2009 07:31 AM
Set it the same as the stock FPR. You can install it and adjust it once it is installed. That's how I did mine anyway and all is well. :)
flash968 12-26-2009 08:29 AM
it has a gauge on it? where did you get that?
Icey1174 12-26-2009 08:37 AM
I bought my gauge separate and installed it on the end of my fuel rail. :)
flash968 12-26-2009 10:06 AM
yeah - that's what i've always seen - i would be very interested in one that had a built in gauge though
