Certified Porsche addict
Anybody running Ecsta V710 225/50R15?
Looking at putting Kumho Ecsta V710 on my 924S track car. Trailing arms lowered, 1.5" lowering springs, -1 camber rear and -3 camber front. I would use 15" PD wheels. I've currently got some 16" PD wheels with Hankook Ventus R-S2 205/50Z16 fronts and those are really close to scraping the struts. I'm really concerned about buying the 225/50R15 and having to loose some of that nice camber. If I go down to the 205/50R15 then I'll gain room for camber but I loose tire width and diameter.
The specs for the V710 in the 205/50R15 are tread width 7.6", diameter 22.9". And the V710 in 225/50R15 is 9" and 23.7". The current 16" Hankooks are 7.2" and 23.9". Maybe the 225's with 1/4" wheel spacers?
Tennessee Region SCCA & PCA Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend) Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11 |
working in the garage
Do you run stock struts or Coil over style? My car is very similar in settings, coil over 2.5in. springs, 225/45/15 Toyo's (8.7 in width) and I can run max neg. camber with adj. plates. My guess is the stock dia. springs/struts would be too close but run the smaller springs and your fine.
