Tech Bulletin Request
Found 602-01 of PET, under part # 951 351 421 00 (86 951 front caliper):
see technical information GR.4 NR.2/86 TIA, rasta |
Really, nobody has this?
The only TSB's that I can find for 2/86 are #18601: engine - drive belt checking and adjusting values; and #18605: engine - low or no oil pressure upon cold start.
Let me add that I checked through ALL of the TSB's for an 86 951, all the way up to 9/05, and, out of the 50 or 60, or so, that I see, there are NONE relating to brakes or calipers. This leads me to believe that what you are looking for is NOT a TSB. |
That Tech Information Bulleting pertains to the composition of brake pads for the 86 Turbo.
If what you are looking for is a TIB, I don't have those. I only have TSB's (technical service bulletins). Sorry about that - my mistake.
Thanks for response, wild man. Mistake woujld appear to be mine., George, definitions of TIB and TSB??
TIB is what Porsche calls them on PIWIS, the electronic information system. TSB is the old term for paper distribution.
| All times are GMT -8. The time now is 09:26 PM. |
