porsche0nut's Avatar
16V vs 8V Engine Mounting
Hello everyone,
I am in a position to buy a project car in great shape minus the engine. It's an '87 944S. The camshaft timing belt went on it and I suspect heavy internal engine damage. I have sourced a running engine from an '84 944 that I can get for a great price and was wondering if the mounting points for the 2 engines are identical? It seems to me that the blocks are very similar, as the major difference is the 16V head in the S?
So if I were to get the '84 engine how straight-forward would it be to drop it in the '87 chassis?
Alternatively, is it worth it to spend the money and get the replacement parts for the 16V engine? As of yet I do not know what is needed.
Thanks for your help!
Old 01-03-2010, 06:41 AM
Not sure on the mounts, but I do believe there is quite some difference in the electrical system as well. If I am mistaken, our more knowledgeable members will surely correct me!
Neil
87 944S
http://guns.claasen.us/
Old 01-03-2010, 07:46 AM
Send a message via AIM to ScoobySteve
I think you're biggest problem won't be going from 16v to 8v but late car to early engine. I believe are several electrical differences.
I would open up the S engine first and see what damage there is. Honestly, the S engines are cool and rare enough now that I think it's worth saving. You might be able to pick up some used tappets to cut down the cost.
-Stephen
00 Boxster S 6MT
03 Subaru WRX w/EJ207 swap
16 Cayman GT4
21 Genesis G70 3.3T
Old 01-03-2010, 08:54 AM
Endat's Avatar
I spent the dough to repair the S engine.. part of me wishes I had spent more and sourced a 968 engine, and the other part knows I made the right decision
Old 01-03-2010, 10:11 AM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
You will need the 944 engine's harness, DME, AFM, etc.
The engine will bolt right in though - I went from an 86 n/a to a 16v motor.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 01-03-2010, 02:47 PM
