Toofah King Bad
Rasta Monsta's Avatar
Door Handles - Year Differences?
They look the same from the outside, except for 968, but are there any differences between 24, early and late 44 handles?
TIA
rasta
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-30-2009, 01:44 PM
VII VII is offline
The early handles have the plastic insert (sometimes smooth, sometimes ribbed) I believe. I'm not sure but I think the early handles did not have the door lock microswitch? Maybe only some cars early cars. The late handles are either smooth or have the porsche script and likely have the microswitch. They both use the same gaskets and all the parts should be interchangleable (cylinder, lever, etc). I have a set of late scrip handles, late smooth handles and an early drivers side handle with the insert which is where I am getting my info from. Someone else may know a little more about them than I.
Old 09-30-2009, 05:17 PM
thekidd's Avatar
Send a message via AIM to thekidd
Early 944's, 924S, 924's, and the "early" later models ( 85.5- 86 I think) have the plastic insert, the 87 and newer models have the PORSCHE script handles (didnt know that they made smooth handles w/o the Porsche script.) The parts are interchangeable from what I remember also, just like VII stated above. I say the 85.5- 86 models have the plastic inserts because my 85.5 did, and they changed some things on the later models starting in '87 ex. wheels went from 7's in rear to 8" I beleive
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 09-30-2009, 05:25 PM
VII VII is offline
I had no idea there were non script late handles as well but I have a pair with the microswitch. They were not filled in or anything and supposedly came off an 87 S2 from the ebay description.
Old 09-30-2009, 05:35 PM
Toofah King Bad
Alright, attempting to slap scripties on a 1980, will let you know how it flies.
Old 09-30-2009, 09:22 PM
rluciano's Avatar
My wife's '86 944, which we bought new came with a script passenger handle and a smooth driver's door handle. My '87 951 (purchased very used) came to me the same way.
Old 10-01-2009, 05:46 AM
ideola's Avatar
Looking at doing the same thing. Results?
I saw a couple of threads that suggested the lock cylinders were incompatible between early 924 and the script handles, but nothing conclusive...can anyone confirm or deny?
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 01-06-2010, 05:47 AM
Catamax944's Avatar
Because your driver's handle was most likely changed with a brand new handle.They don't make the script handles anymore,all new handles come with smooth finish now.Only original late 80's handles are script.
In Europe all 85.5 onwards had script handles.Here's a pic of mine.
Catalin
'86 DD
Old 01-06-2010, 06:37 AM
On Boost
Paulyy's Avatar
87 S2? are you sure
S2 are 1989 - 1991
& my car is an 86 euro spec with no script
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 01-06-2010, 03:24 PM
ideola's Avatar
Hey Catamax, I've often wondered about painting the early style handles body color. Do you have any pix from a greater distance showing the complete effect?
Old 01-06-2010, 03:30 PM
Will program for food
ghnat's Avatar
My S2 came with smooth... although I bought it used
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 01-06-2010, 04:03 PM
Catamax944's Avatar
Catalin
'86 DD
Old 01-06-2010, 05:15 PM
ideola's Avatar
Very nice, thanks for sharing! Something else to chew on now...hmm...
Old 01-06-2010, 07:31 PM
GostRidr's Avatar
LOVE IT! I always liked the body color handles of the 968 but want to keep my cab stock. THAT is something I would do and it looks great. How long ago were they painted? Any issues keeping the paint on them. GORGEOUS!
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 01-06-2010, 09:36 PM
drift a 944's Avatar
If prepped and painted properly they should last just as long as the paint on the rest of the car.
The lock cylinder might be a little different in design but should still swap out easily.
And to add to the controversy, my 86 n/a came with scripted handles on both sides, as did my 86 n/a parts car, and also a friend of mine with an 86 n/a. My 951 has 968 handles that were swapped on. I think Catamax944 is right about the smooth handles being a reproduced part.
- Elliott Grafton - 944Barn
Old 01-06-2010, 10:56 PM
Catamax944's Avatar
They were painted on 05-07-2008 ,the paint on the handle itself still looks great like the day i painted it but i also painted (in black)the trigger of the handle,the one that you pull to open the door,don't know how it's really caled,and the paint chipped in some spots.I preped them very good,i'm very sure it was the paint that was no good.After painting i did the script with a black CD marker.
Catalin
'86 DD
Old 01-07-2010, 06:10 AM
