oil pickup tube installation
Assembling an '88 NA 8V. I have 3 seals in my lower gasket/seal kit that look like they could fit the oil pickup tube. Black, Red/Orange, and Clear. The black one seems to be the correct diameter, so I used it. It seems like it is too tall because it squished out and there is a gap between the block and the flat area on the pickup tube:
Does that look right to you?
Old 01-07-2010, 02:37 PM
Black one in the kits is for the early oil cooler housings, not the pickup tube.
Doc Wilen
86 951
Old 01-07-2010, 04:26 PM
totally makes sense. I probably mixed them up. thanks!
Old 01-07-2010, 06:00 PM
Redline Racer
HondaDustR's Avatar
The seal from pelican is black. Maybe it's just a different color in the gasket kit.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-08-2010, 06:31 AM
