Zombie
Steering Wheel Removal Tricks? (the nut is out!)
OK - this is really taxing my patience. I've long been able to easily remove the 24mm nut holding the steering wheel in place - and I've tried lots of WD-40 and PB Blaster - but the steering wheel just will not budge. Nor can I see how to get a puller to engage to help with this. Any tricks to this? Thanks!
winter-hater club member
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Guest
Posts: n/a
+1. It's a pain, but if you keep at it and are patient, it will eventually come out.
hot heat gun-http://www.sears.com/shc/s/p_10153_12605_00927801000P(variable heat with pencil nozzle ) around center wheel aluminum area directing around column nut shaft
just don't hit yourself in the face with it when it finally breaks free!
u can rent a steering wheel puller from autozone/pepboys.
