cylinder head pressure relief valve
87 944 non turbo
what is this cylinder head pressure relief valve, and why doesn't my car have one? is it under something..can't seem to see it...whats it for...
Nobody Special
You can't see it until you remove the camtower since it mounts in the head between camtower. Here's an 86 Turbo head. Supposedly it helps prevent drainback of oil from the camtower so your lifters stay pumped up.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD Last edited by 2Tight; 11-08-2010 at 12:13 PM.. |
How large a valve is it ??
Is this the same valve,. that's in the oil cooler housing ??? FM
Nobody Special
You're thinking of the oil pressure relief valve (OPRV) in the block. The OPRV helps control general oil pressure throughout the entire block, the one in the cylinder head deals only with oil supply to the cam, cam journals, lifters, and valve stems.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
I think the pressure relief valve is only on the 88 2.7 L and 3.0 L twin cam engines.
Jim Richmond 944 Spec race car, SoCal NASA & POC 01 Boxster S |
Nobody Special
You are correct about that being on the 89 2.7L and 3.0L. The 944S 2.5L also has one though. It's actually called a pressure reducing valve in the FSM and is in addition to the anti-drainback valve. I was confused about what his original question was since I couldn't see his drawing at my work computer.
I sure would like more info on this part,...I dont think I have that in my pile of parts???? for the 86 NA....P/ N Please anyone......Thanks Frank
does it exist on a 86 944 turbo head?
Well ,..I dont think its for a 86' 2.5 plus its special order 400.00 part with a NO return...FM
