Unhappy Oil in Coolant (1983 944)
I was driving my 944 the other day when the temp guage got really hot, so I stopped and pulled over and there was a gurgling noise coming from the coolant resevoir. Upon further inspection, I realized that oil had mixed with the coolant in the cooling system. The car has been parked since this happened. Any ideas about what it could be or how much to fix? We're thinking head gasket but not sure. Thanks in advance!!
Old 11-14-2001, 10:41 AM
85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
I would guess it's the oil cooler seal, my oil and coolant started mixing and it was the oil cooler seal, dont know how much though sorry, a friend did mine
PORSCHE: NOTHING EVEN COMES CLOSE
Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels.
95 Infiniti G20 dark red metallic-for sale soon
87 BMW 325ic Bronzit, stock(for now)
Old 11-14-2001, 11:17 AM
I'm off the hook.....
Porsche Crest Oil in Coolant
I too have an '83 944 with oil in the coolant. 99% sure it is the oil cooler. Is a bugger to get to. Don't drive it if you can until it is fixed. There is a possibility that the coolant is getting to the oil. Then you'd have bearings (crank and cam) to consider. The repair kit is $50 to $70 dollars... the cooler (some say to change it in case it's not just the seals leaking) is $250 or so. Most shops will quote 3 to 5 hours (it takes 90 minutes or so according to the book). You'll be flushing the oil and cooling system when you are done. Good Luck. Where in Calif. are you?
Old 11-14-2001, 11:42 AM
brett25's Avatar
hi. this exact problem has happened to me. the problem you are describing is very likely the seals around the oil cooler. apparently this problem is common on later 944 models. i just got my car back yesterday. the total cost of repairs was $325.00. $250 in labor costs, the rest in parts cost. it is important to catch this problem early, because you dont want the coolant to get into the oil. hope this helps
Old 11-17-2001, 07:47 PM
I'm in Northern California ( Sf Bay Area) Thanks a lot for the help, now any ideas on how to get access to the oil cooler? Looks a little tight. Is jacking up the engine a possibility? Thanks again
Old 11-17-2001, 09:18 PM
I had my oil-to-coolant heat exchanger repacked 3 years ago in a european-car garage in Washington State. It took a morning and cost about $270.
-Dave-
1969 911/3.0l SC
Old 11-18-2001, 03:50 PM
Smile
Thank's guys, I got it off and am ordering the parts tomorrow. Hopefully my 944 will be running by thanksgiving.
Old 11-18-2001, 11:26 PM
