-   -   What mileage when you had to replace valve seals? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/522845-what-mileage-when-you-had-replace-valve-seals.html)
bebbetufs 01-23-2010 12:50 AM
I'm toiling over whether to change valve seals or not as I have the cam tower off.
Engine is a very low mileage unit and burns no oil. 62K miles.
What is a rough estimate of their life expectancy in miles?
Are these seals affected by age the same way as o-rings and other rubber seals? They seem to me to be of a longer lasting material.
krystar 01-23-2010 07:13 AM
so how bad is it burning oil on startup and high engine load?
bebbetufs 01-23-2010 09:05 AM
It does not burn oil on startup or under load - yet.
I'm simply trying to find out how long they can be expected to last on a street car.
mattdavis11 01-23-2010 12:52 PM
Where is the option for over 200K?
bebbetufs 01-23-2010 01:36 PM
:) good point. Unfortunately I can't change the poll once it's done!
John_AZ 01-23-2010 04:20 PM
I voted 100K because that is when my head gasket went.
The seals may have been OK.
If you decide to install new valve stem seals, there are a couple varieties besides rubber that come in the Victor Reinz HG kit.
bebbetufs 01-26-2010 03:30 AM
Judging by the poll mine should last another 100K at least. However, when I took of the exhaust manifold I discovered a blob of black crud on the bottom of one of the exhaust valve guides. Could this be burnt oil?
bebbetufs 01-26-2010 03:36 AM
wild man 01-29-2010 02:54 PM
It could, and most likely is. It would appear that you have a leaker. With such being the case, good time to replace the set. I guess you could just replace the bad one though.
P.S. - I will have what you need when I replace my compressor section with a K27 compressor, tentatively slated for may or june. PM me at that time if still needed.
HondaDustR 01-29-2010 08:51 PM
Make sure you get the reddish colored vitton seals rather than the regular black rubber ones. The vitton stays pliable longer.
bebbetufs 01-30-2010 01:33 AM
The ones I have are grey on the outside and rubber red on the inside. Are those the ones?
HondaDustR 01-30-2010 10:07 AM
I don't know.
