Another engine oil level light thread....
A little different from the rest. My electrical issues with temp sensor and voltmeter readings and starting issues seem to have been resolved with installing a new engine ground cable.
On start up and idle there are no warning lights on. However when the engine is revved up to 3k rpm the oil level warning and "!" come on. Pressure is good and oil level is full. Any thoughts? Where is the level sensor located? I might just disconnect it.
'87 911 GP White "casper" '79 930 Copper Brown Metallic "beast" '93 968 Amazon Green Met "moby" '97 Esprit V8 "flat eric" '97 993 Speed Yellow "tbd" |
There are two wires just below the oil filter, seperate them a little. My car was doing that blinking like crazy.
1985/2 - 944 Good ten foot car |
Sounds like a ground issue.
I would consider cleaning the instrument cluster grounding stud and all brown wire spade connections under dash. Since the Oil pressure is reading good then I would assume the engine is grounded. They make their grounds from different places. When you add RMP's you increase the charge/voltage being created by alternator. This means that a marginal ground connection is bogged down trying to return the current and can cause a spike in resistance.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
All Spooled Up
The one on my 924S is fine, as long as the car does not move after being started. But soon after the car starts moving, the light starts to blink. What's up with that?
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
