Custom User Title
mikepellegrini's Avatar
86 951 Control Arms
Does anyone know if the 86 control arms are unique or can I use CA's from an 87+?
The 86 and 87+ numbers are the same, except that the late parts start with 944... and the 86 parts start with 951.
Is it that the 86 951 and NA parts were different, then in 87 they switched to both 951 and NA using the same part?
I ask because it looks like I need to replace the driver's side control arm and an just wondering what options I have. My current CA has a "pocket" you can feel with your finger - where it's slightly out of round - and I don't think the rebuild I just did is gonna last.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 01-22-2010, 08:14 PM
That Guy
Techno Duck's Avatar
The '86 951 arms are early offset.
Old 01-22-2010, 08:18 PM
Custom User Title
Meaning that they are unique and won't interchange with other years? Cool. Thanks.
16 Ford Expedition
Old 01-22-2010, 08:40 PM
Toofah King Bad
Rasta Monsta's Avatar
Meaning you can swap in early steel arms. . .for cheap.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-22-2010, 09:18 PM
Custom User Title
The steel arms are cheap - and the ball joints cost like $26 or something ridiculous.
But I thought the 85/1 and 85/2 geometry was different - and then changed again in 87?
16 Ford Expedition
Old 01-22-2010, 09:26 PM
smokin_944's Avatar
The arms changed from steel to aluminum in 85.5 IIRC. From 87 on, the offset was changed.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 01-24-2010, 07:06 AM
