944 oil cooler
Is there any way to run an additional oil cooler on the NA 944? (if this is stupid it's 'cause I'm new to '44s)
2002 C2 Cab, 1982 sc, 1978 sc, 1976 s,1985.5 944, 2003 Honda Pilot, 2001 Volvo X/C 70, 1977 FIAT 124 spyder (an abarth someday), 2 1984 Vanagon Westis 1958 BugEye Sprite, 1960 BE Sprite, 1978 Yamaha XS11 1970 Honda 750 K0, 1982 BMW R65RT, 1997 Duc 916 |
Redline Racer
Yes there is. The 944 turbos ran an external oil cooler, and the housing the oil filter screws onto is interchangeable between the two motors. The turbo oil cooler housing has oil line connections and it uses a straight pipe in place of the internal oil/water cooler used in the NA versions. I have no idea if the NA's have radiator mounting or oil line routing provisions that the turbo car might have. Someone else would know the details.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
So the basic parts required would be the housing, lines and cooler?
That Guy
The easiest method is to get a sandwich plate that goes inbetween the oil filter and filter housing. The sandwich plate will have threads for AN fittings and you can plumb an oil cooler off that.
BAT Inc. has pretty much everything you need to get setup, though you can source everything yourself. It might just be easier to go through here though. British American Transfer The 951 cooler will work also, but is more trouble than its worth i think. The stock 951 cooler is not the best either, a new Mocal or Seatrab cooler will be much more effecient and offer more flexible mounting options. Plus you do not have to question what debris made it through the cooler (did the car spin a bearing..etc).
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 02-01-2010 at 05:36 PM.. |
