944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
What kind of coolant should I use???
I have had this 944S a couple of weeks now and still will drive it another week or so (then put it away). I'm not sure if it's winterized in the coolant department. It has coolant in it, but I don't know if it is ok in this low Nova Scotia temperature. What kind of coolant should I put in the car over the next few weeks???
Old 11-21-2001, 07:45 AM
AFJuvat's Avatar
Use coolant that is rated safe for aluminum engines AND is phosphate free.
Any of the coolants listed as "Dex-Cool" approved work just fine.
WHen changing your coolant, make sure you bleed it completely
AFJuvat
Old 11-21-2001, 07:49 AM
So, I can't just add new coolant into the existing coolant? The stuff that is in it now is like a clear color. I know most "winter" coolant is blue. I think I'll get the coolant changed when I get my thermofan switch replaced. Speaking of that, does anyone know where the fan relay is located on a 88' 944S? I've been told that my fan problem is either related with the thermofan switch or the relay. I wanna try the relay thing first, then if that isn't it, I'll try the switch.
Old 11-21-2001, 08:25 AM
DennisR_944's Avatar
Prestone's Phosphate free coolant is orange, as is most that I've seen.
Dennis Russell
Indianapolis, IN USA
1987 944 n/a
RLM #020131-3340
Old 11-21-2001, 10:05 AM
Diesel's Avatar
I like Saturn's green coolant. Phosphate free, and Saturns engines are ALL aluminum.
Dan, '78 Pearl/white 924
2002 VW Jetta GLS TDI
95 Saturn SL2(sold but missed at times)
83 Mercedes 300D turbo-diesel
Old 11-21-2001, 02:47 PM
asm asm is offline
asm's Avatar
fan relay
Try the relay in the lower right corner of the fuse box. Should be part 944.615.104.03. Good luck.
asm
Old 11-21-2001, 03:48 PM
