Griffinroydonal's Avatar
wiring anyone ?
I am cutting up a wiring harness from a 1984-944 and just wanted to know if anyone needed any of the connectors or bits of the wiring ? Also have early fuse panel and relay holders if needed. I am a real scavenger
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 02-08-2010, 07:14 PM
944 Newb
I might need the connectors to the idle stabilizer valve. Are those two grouped together are is it in two spots? Thanks.
Old 02-08-2010, 08:24 PM
Post a picture and I will pull them out of the harness. I know this stuff is good for spares.
I Pull out of harness , Bag , Hang on wall and Save for later.
Old 02-09-2010, 02:09 AM
pinball_0's Avatar
I could use the wiring on the hatch that goes from the wiper motor to the rear fender connector (connector included) if you are pulling that wiring out.
Old 02-09-2010, 03:46 AM
