-   -   turbo vs. n/a transmission question (not a strength question) (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/523907-turbo-vs-n-transmission-question-not-strength-question.html)
matthewb 01-29-2010 03:55 PM
Does anyone know why the 944 n/a uses a regular bolt for holding the rear input shaft bearing on but the turbo uses the internal triple square bolt to hold it on? The turbo shaft has a lot more machining inside of it. I wasn't sure if there would be some need for fluid to come up through the shaft and out the back of it. Seems like a lot of extra machining and an odd fastener. There must be some reason.
