-   -   Is this the oil relief valve? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/525403-oil-relief-valve.html)
marko 02-07-2010 01:30 PM
I can't tell exactly what this is from the PET, oil pressure relief valve? It's leaking oil.
http://forums.pelicanparts.com/uploa...1265577722.jpg
http://forums.pelicanparts.com/uploa...1265577759.jpg
John_AZ 02-07-2010 03:10 PM
Without getting under my car, you are pointing to an oil plug-part 37. You should just need an aluminum crush washer M18x24 to seal the drip.
Get another for the oil pressure sender-part 30. Clarks says it is an M18x24 crush washer. I use all aluminum crush washers.
Get a third for the OPRV valve-part 31. Crush washer M20x24, The OPRV valve head is 24mm opposite your arrow.
If you take off the oil pressure sender, take care with the terminals. They are hollow and will snap/break easy!, Do not reverse the wires. If you do the oil pressure guage will peg to 5 with the key in.
http://forums.pelicanparts.com/uploa...1265583265.jpg
GL
John_AZ
marko 02-07-2010 06:18 PM
Oh good, that sounds pretty easy. Thanks for the help!
HondaDustR 02-08-2010 10:06 AM
Interesting. I had the wires reversed when I got my motor back together and the guage didn't peg with the key in and the motor off, but would instantly peg as soon as it got oil pressure. It would peg with only the key on if they were disconnected altogether. It must have been the low pressure switch for the idiot light messing with it.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
