Architecture & Porsche's
Oil cooler: only 4 bolts to remove it?
Doing a reseal on my 951 with the engine still in the car (don't ask): does the oil cooler bolted above the lower balance shaft housing really just have the 4 13mm bolts holding it in? I've removed them & banged/tapped a bit but no-go.
Thanks, mark
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 02-07-2010, 05:50 PM
Proprietoristicly Refined
John_AZ's Avatar
Looking at the oil cooler plate/housing gasket it appears to have 4 holes for bolts.
Did you remove the OPRV valve with the 24mm top from the oil cooler housing?
EDIT: This is the only photo I could find
If it still sticks it may be due to RTV silicone sealer that was applied too thick on the housing seal. It may have sealed the housing to the engine block.
GL
John_AZ
Last edited by John_AZ; 02-08-2010 at 04:21 AM.. Reason: Photo of oil cooler plate
Old 02-07-2010, 08:33 PM
IT's never been out of the car & difficult to get tools in there, even with the exhaust manifolds removed. All 4 bolts are off but something else is binding it in there for sure.
M.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 02-08-2010, 07:43 AM
