Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
Porsche Addicted
bnv944's Avatar
Cool how to destroy your camshaft in 5 (or less) easy steps (pics)
1) ignore that slight barely audible knock and tell yourself is because of the cold
2) decide the knock is bad enough and change the lifters
3) now tell yourself that knock is just the lifters wearing in
4) in a matter of 15 min, decide that what sounds like a hammer in your valve-train oil starvation, and bring her home to get checked up on
5) drink yourself to sleep after noticing chunks of metal in your distributor cap.
1987 944 n/a. project car.
- It's amazing how a $3 part can end up costing you thousands.
"when the wrench starts to turn, but the bolt does not.
The project will take, longer than thought."
Old 02-08-2010, 08:07 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Redline Racer
HondaDustR's Avatar
Well, extra lucky it was external to the motor and didn't throw the timing enough to bend valves. 8v cams are almost a dime a dozen used. Still it sucks.
1987 silver 924S - Rebuilt motor! Bottom end balanced, Custom mild ported head, Port matched intake, LR 944MAX chip, Bilstein shocks, no more K&N air filter, MSD Blaster 2 coil (no ballast resistor), Steel braided brake lines, Magnecore wires, Weltmeister throttle cam.
Old 02-08-2010, 08:42 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Proprietoristicly Refined
John_AZ's Avatar
Great pictures.
Additional advice----Change the camshaft gear bolt to the new style.
Old 02-09-2010, 04:11 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Porsche Addicted
bnv944's Avatar
i dont know if the valves are bent or not. i have to take the cam tower off to inspect for more damage. thats as far as i got last night. has this happened to anyone else? the woodruff key just shearing and destroying things like that?
Old 02-09-2010, 06:26 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Yes. Diagnosed the noise as a loose camshaft bolt, tightened it and drove it. While changing belts and replacing gaskets and seals, found the end of the cam is pretty beat up. Swapping in the cam tower from a parts car. It was in a thread posted last week or so.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
That's the whole problem with science. You've got a bunch of empiricists trying to describe things of unimaginable wonder.
Old 02-09-2010, 06:50 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
I have a full head from an 84 with the cam tower and all that I am looking to get rid of. I will seperate them if you would like only parts of it. Send me a pm if you are interested.
Matt
Old 02-09-2010, 07:29 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Redline Racer
HondaDustR's Avatar
FYI, there's a small difference between a late cam and an early cam. The late has a slightly more agressive exhaust profile with longer duration and 1mm more lift. The turbo cars share the early grind as well. A late cam can be dropped into a turbo or early NA for a slight improvement.
Old 02-09-2010, 07:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Schumi's Avatar
I believe the cam sprocket bolt is a torque-to-yield bolt, and should never be reused. Else things like pictured happen.
Current car: '87 Guards Red 924S now my daily driver.
Project car: '87 Zermatt Silver 924S NASA-spec / F-Prepared racecar project
Mechanical Engineer & Researcher
Old 02-09-2010, 10:46 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Porsche Addicted
bnv944's Avatar
well before, i was toying with the idea of buying a used complete engine and completely rebuilding it from the block up. but i wasn't expecting it to happen this way. if anybody knows/has a full engine they wanna get rid of for cheap let me know.. ill try to swap the heads and cams out with the used one, keep the rest of the parts for spares
anyway. pulled the cam tower off today and have more pics that ill upload later. i found a crack in the head, other damage to the springs. not pretty.
Old 02-09-2010, 11:04 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Don't know if that's true, but for less than $3 from our host, I'm replacing mine.
Old 02-09-2010, 11:06 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
^ It's true.
When this happened to me I upgraded my early car to a late cam. Blessing in disguise, really.
'84 924 Euro - yup, I'm doing the clutch.
'83 944 - looks like ass, runs like horse.
'82 931 - might make a good planter.
'77.5 924 - to go to mother-in-law as payment for wife.
'79 924 - now what do I do with this?
Old 02-10-2010, 09:26 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
Porsche Addicted
bnv944's Avatar
more carnage
result of not paying attention ^
need to fix this...
Old 02-12-2010, 04:18 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
One apex at a time
Dean924s's Avatar
Hmmmmm I just replace the cam sprocket bolts with grade 8 metric bolts from the local Hardware store. Cost is around $.95 I keep replacements to many of the nuts and bolts on these motors/cars in bins on the shelf. The local Hardware store carries most everything for very short $$$$. For a little more I can go stainless steel and considering the reaction that regular steel and aluminum I have been replacing many of the smaller easy to brake bolts with stainless steel.
Respectfully
Dean
"WAR - It doesn’t matter who is right only who is left."
"Physics - A silent killer."
Car Specs & Mods
http://clarks-garage.com/phpBB2/viewtopic.php?t=2937
Old 02-12-2010, 05:41 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Redline Racer
HondaDustR's Avatar
In the 3rd one, I wouldn't worry about it. I guess maybe you could JB weld the chunks back into place and sand the weld smooth, but it's not really a load-bearing area and has the gasket surface inboard from the locater pin hole, so it should still seal.
That intake can get kind of nasty if it hadn't been cleaned in awhile. The typical German overengineered deal with the crankcase breather system. Any crankcase vacuum leaks will do that alot more, like oil dipstick seals, rear balance shaft o-rings, etc. as well as leaky piston rings, but it always seems to build up at least some mess over time regardless of the state of everything else.
GL on it. You should be able to find a good used cam for fairly cheap.
Old 02-12-2010, 09:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
i've been messing with these cars since 89. Have never seen that happen before. Got a call from someone in Myrtle Beach Monday saying they had a bad lifter and needed a replacement. The car got towed to my house today and your thread helped me find the problem in less then 5 min. Identical problem. Looks like the cam bolt backed out and the woodruff key got stripped. Thanks you saved me a bunch of time trying to figure it out. You learn something new everyday. Now I need to call my freind and give him the bad news.
Old 02-13-2010, 02:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
One apex at a time
Dean924s's Avatar
Locktite is your friend. This is one place where it is a must. I am betting the bolt was removed at some point and not torques properly AND not locktite was applied when reinstalled. I have seen this many times over the years.
Respectfully
Dean
Car Specs & Mods
Old 02-13-2010, 04:52 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #16 (permalink)
Just thinking out loud
mattdavis11's Avatar
BTDT. I bought a used cam and cover for $125, including the seal. Pretty easy fix.
91 FJ80
84 Ram Charger
58 Willys
Old 02-14-2010, 05:30 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #17 (permalink)
Porsche Addicted
bnv944's Avatar
nah locktite was used, i guess it wasnt torqued down enough tho.
Old 02-14-2010, 11:09 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #18 (permalink)
Join us in Monterey for the Pelican Wine Tour & Canyon Run!  Click Here!
Redline Racer
HondaDustR's Avatar
Yeah, it's tempting to go easy on it, especially if you've ever had to drill out a stripped one (.. not fun!).
Old 02-14-2010, 11:31 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #19 (permalink)
Looks like the one I'm working on bent a valve also. Cam, cam sprocket, and cam nut are all toast. It's going back together with used parts monday. Thank god for parts cars or this one would not have been saved. And yes locktite will be his new friend.
Old 02-14-2010, 11:56 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #20 (permalink)
Tags
camshaft, engine knock, lifters, timing, valves
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
