radiator woes
whats it take to pull theradiator on a 1987 944 n/a? it looks like an easy job. any suggestions?
thanx |
944 N/A '83 |
Radiator replacement
Suggest you check the Haynes manual. I replaced the radiator on my '83 na a few years ago with no problem. Replacement is straight forward. It does take a while and you end up with collant everywhere. You must jack the car up unless you're really skinny. Finally, be sure to bleed the system really well after replacement.
asm |
