88 Turbo spings on an 86 N/A ?
I have an 86 N/A and recently have taken possession of the strut towers w/hubs and rotors from an 88 turbo. How can I tell what the spring rate (lbs) is on the 88 Turbo springs and are they interchangeable with my 86?
Old 02-16-2010, 01:02 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Check Clarks Garage
Depending on the 951 options OEM, you may have up to 4 different rate springs...
Look to see the # of color dots on the springs and what color, that will tell you what rates you have there.
944 Technical Information
Later, Jean
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968 & 911 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 03-03-2010, 10:24 PM
No matter what, they are going to raise your car, and the spring rate is only slightly higher. You're better of with aftermarket springs of 200 lbs/in or higher rate
Old 03-04-2010, 01:09 AM
Toofah King Bad
Rasta Monsta's Avatar
Swapping the springs and leaving the torsion bars stock is not the best approach, IMO. The factory setup already understeers. . .stiffening the front will only make it worse.
You might consider starting with the biggest salvage sway bars you can find, front and rear, and see how you like the handling before you start toying with the spring rates.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-04-2010, 07:52 AM
Going from 128 lb/in to 200 lb/in is not going to change the charactaristics the way you think it will, due to the fact that the car rolls SO MUCH with the stock springs. You will still be on the sidewall a little on the track with 200 lb springs and the rear will not be, even with a little more camber in the front. In theory yes stiffening the front will give more understeer but not in this case..... 200 lb/in is still very soft and we haven't even talked about alignment yet.
Old 03-04-2010, 11:41 AM
Toofah King Bad
Okie dokie!
Old 03-04-2010, 06:23 PM
