Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Front Bumper Shocks
I am doing a little experiment on the front bumper of my 85.5/944 and have seen where others have moved the bumper further back to be more flush with the front of the car. To me this says a modification of the bumper shocks is in order. So my question is if I cut off the rear of the bumper shock is it spring loaded or hydraulic - if spring loaded what direction should I aim the rear of the shock and how far will I have to go to retrieve the now loose part . Do the bumper shocks come apart normally or? How does one modify these???
Thanks.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 02-17-2010, 12:34 PM
ideola's Avatar
The bumper shocks are filled with some type of hydraulic fluid. The technique I've always heard described is to drill a hole (where safety goggles) to drain the fluid, then compress the shock to the desired depth. To fix the shock at the desired depth, you can either weld them at the compressed length, or possible drill and insert a pin / bolt arrangement.
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 02-17-2010, 12:54 PM
unindicted co-conspirator
looneybin's Avatar
i drilled out a bumper shock once to compress the bumper.
when the drill bit broke through it was like a fire hose of fluid.
Maybe a pint of fluid - It blasted all over me and the ceiling of the garage.
make sure you wear goggles and expect the fluid to be under a LOT of pressure.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 02-17-2010, 01:00 PM
Why ruin your shocks unless you have another set waiting to be put back on your car? Remove the bumper and the shocks and measure what distance you want them to be and weld up a bracket to reattach bumper to the car. As stated above the fluid is under a heck of a lot of pressure. You not only need good eye protection, but also wear leather gloves. That kind of pressure can force its way into your skin and cause a bad infection.
Cheers,
Larry
Old 02-17-2010, 04:23 PM
Garage Helper
I do have another set of Bumper Shocks (eBay Specials $9.99 pr.). I will probably drill from the bottom with a 1/16" drill and aim the spray into a large garbage can. Then drill and pin from the side.
I will still have my original bumper shocks if I ever want to go back to stock - just put them on the shelf with other repair stuff for now.
Thanks for the info and the warning of high pressure oil -
Old 02-17-2010, 06:04 PM
VII VII is offline
The oil is not that high pressured. I would say I got a couple feet of spray from both shocks if even that. It's easy, quick and the only danger is in getting some fluid on your shirt; no big deal. Shocks are cheap (as you demonstrated with your ebay purchase) so there is no point in going another route.
Old 02-17-2010, 06:39 PM
Garage Helper
Probably a hydraulic fluid under gas pressure?? The hydraulic fluid itself will not compress above the atomic level but a gas will compress...
Old 02-17-2010, 07:11 PM
VII VII is offline
meh, some sort of fluid. Anyway, whip out that drill and get to work!
Old 02-17-2010, 08:02 PM
