pimpin944's Avatar
Question looking for info on half shaft install
Hi, i just got my new axle assembly (left side (driver)) pulled it out of box, and it can't be as easy as it looks. just pack w/grease, unbold old one (with car safely supported of course) then bolt on new one? there has to be more. I've searched the net for any install instructions and found nada! could anyone please help with any tips, tricks, warnings, any info. I hope this might help others that may, one day also need this info. Thanks Guys!
Old 02-19-2010, 04:49 PM
Born2bwild1191's Avatar
I actually need to do this myself sometime next week. From what i've heard, it really is that easy. Clarks-garage.com has an installation guide under "CV Joints" (thats what they really are, one on each end of the half shaft). I believe the bolts holding each joint on are triple squares, or "cheese heads". Make sure to get the right tool, as a regular allen head could strip the heads and then you have trouble. Did you get replacement bolts with the half shaft? I've heard its a good idea to replace those as well.
P.S. - Welcome to the forums! These guys are practically geniuses with these cars, you have come to the right place.
'87 Guards Red 924S - First Porsche - SOLD 5/21/10
'67 Red VW Beetle - Restored by me and my dad, 2115cc motor.
'87 951 - Silver/blk, full leather interior - LR Chips - 3 bar FPR - LBE
'92 Ford F150 - Winter truck
'04 Yamaha R6
Old 02-19-2010, 06:32 PM
pimpin944's Avatar
Thanks for the welcome & info at clarks, was very helpful. I guess it is just that easy to swap them out. Sweet!
Good luck with yours born2b. Thanks again!
Old 02-19-2010, 07:36 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Welcome
Yea, the CVs are pretty straightforward. Please note: the cv bolts have been known to loosen up on folks. (very embarrassing) so, after road testing a bit, go back under and check the torque on all of them. Once you are sure everything is nice and solid, I paint a little line on each bolt so that I can visually see if any of them loosen up rather than checking the torque on each of em. Yea, it seems a bit extreme, but, it gives me peace of mind. inspect these bolts regularly. Do a search on CVs and you will see what i mean.
Welcome to the asylum.
Born2: way2go and good luckwiththat.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 02-19-2010, 08:34 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Unhappy
Why is it that when they are installed at the factory the CV Bolts can stay in place almost forever, but once removed, even though re-torqued to exactness they will sometimes loosen over time - I check mine now every two or three months.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 02-20-2010, 01:44 AM
ideola's Avatar
Because they are stretch bolts and designed for one-time-use. FSM requires new bolts. However, even with new bolts, there are still reports of them backing out. Personally, I believe it is because CV grease gets into the threads of the inner and outer stub axles.
Many guys that track or race have reported such failures, and have resorted to safety wiring. We now have a much better (and easier solution):
We just completed a massive group buy (107 participants), but we're currently running a 10% off special through the end of the month on the Stage8 fastener kit (and a few other items).
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 02-20-2010, 03:44 AM
pimpin944's Avatar
Thanks for all the input! I was wondering, how about loc-tite? has anyone tried this to prevent bolts from backing out? that was my plan for the bolts, unless there is a reason this isn't a good idea. (don't know why that would hurt anything, but I guess it's better to ask someone with the experience)
Old 02-20-2010, 08:19 AM
ideola's Avatar
Loctite hasn't solved the problem either.
Old 02-20-2010, 09:39 AM
