New Guy
Hello everybody!
I have a 1986 944 that I have owned for a year and I drive it only in the summer daily. I have no major issues with the car except when it first starts, I need to give it some gas until it is warmed up. If I do not, it stalls. It has done this from day one. I plan on getting the belts done this Spring in Anchorage a long with a good going over by the dealer. I have an issue with the sun roof not lining up correctly in the front. The motor works fine but the cable binds. Any ideals? |
your average wrencher...
tps sensor......
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold ![]() 1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
Proprietoristicly Refined
+1 good place to start.
You might as well rebuild the throttle body with the Arnnworx Home Page Throttle body rebuild kit. Same person who makes the cam tension tool and great web site of tech info. |
Garage Helper
Also check the idle speed adjustment - on throttle body.
Clark's Garage Home Page FUEL-08, Idle Speed Adjustment
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word Last edited by Cocacolakidd; 02-20-2010 at 12:47 PM.. |
Welcome!
and were are all wanting to ask how much it costs (estimated) at the dealership in Alaska......will they even work on these old gals?
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Professional Bull5hiter
And give the TB a real good clean out with a carbi cleaner.
Jeff 83 944 Guards Red 23 718 GT Silver |
Thanks for the welcome and info. If I remember correctly it is about $140 an hour at the Morrison's in Anchorage. I do not have any documentation from the previous owner on the belt and he never did replace it. He drove it one summer and parked it when he deployed. Came home and needed the money. Is there any warning when the belt is about to go? Less power? She runs fine, I just want to be proactive.
There should be an inspection port on the top of the cam belt cover if you remove the rubber cover (at least there is on mine).. I think (but im not sure) you should check for typical rubber wear like shiny-ness, fine cracking and any evidence that it's getting weathered.
Evidence of the balance shaft belts being worn is just a little more vibration in the engine than normal... TimingBelt should be done at the same time since theyre all in the same place. I could be wrong (and i dont doubt it). And yeah, cleaning your ThrottleBody is a good idea too.. Last edited by Endat; 02-21-2010 at 02:56 PM.. |
Get the belts changed. It may cost you a couple of hundred dollars or more for a shop to change the belts but the consequences are Bent Valves The 944 is an interference engine and the valves hit the pistons if the belt slips or breaks. If you do not know when the belt rollers have been changed-replace them. Replace the can gear bolt too. The belt gets retensioned at 1500 miles. Well, now we are up to $700 in parts and shop time if you go to a mechanic. DIY is about $250 for parts +-(plus tools). We can help. GL John_AZ 1988 924S 61K + 1987 924S 114K DD |
Belt tension gauge is about 600 bones if you get the proper one, but I think some guy makes a kit that will do the same thing for about 150
